VintageRacer
Mar 20, 2015Explorer
The ampacity of the wire is about the same for 12Vdc and 120Vac, so your training will see you through. On high amp DC loads always look for the voltage drop over distance as well as the ampacity, this is particularly important for inverters. Your inverter is quite small, I would think about wiring it for a 1,000 watt inverter just for ease of possible future upgrade. I used 14 gauge stranded wire for all my low current DC loads - radio, lights, etc, 12 gauge for the fridge and furnace (the voltage drop thing), and did all home-run grounds to a dedicated ground bus. To make it really easy I color coded the wiring, and ran out 50 foot spools, tied one end off and made them twisted pairs with my electric drill. Took seconds to put a really nice twist into the pair of wires, and made it neat and easy to run. You know of course that low voltage DC and 120VAC can never share any fixture, must always be in separate boxes and conduits. Chaseways I think are OK to share. You also know to treat the RV AC panel like a Pony panel and float ground vs neutral. The bond is always provided by the source of power, be that plug on a pole, generator or your inverter (if you wire inverter loads through your panel, which that inverter is not rated for). Always tie all grounds to the chassis of the RV.
Brian
Brian
