RoyB
Mar 20, 2015Explorer III
I used what is called Marine BOAT WIRE 2-cond #12 gauge in a covered sleeve enclosure for all of my 12VDC lite wiring. Every cable carried its own ground wire. Although some DC wiring is to the trailer frame all of it comes from the DC Power Distribution Center with 2-conductors. One +12VDC and the other -12VDC. All of my 12VDC Battery wiring was 4 GAUGE ANCOR BRAND marine wiring which always had ANCOR ring terminals on both ends where possible. All of my BATTERY WIRING components were BLUE SEA products that has STUD connections.
I also cut my own battery cables and use a 8-ton hand crimper to properly install the ring terminals which have adhesive type heat shrink ends...
Being for my OFF-ROAD POPUP trailer I included all of the under floor wiring in PVC FLEX TUBING which was routed the whole underside of the trailer and came up through the floors with PVC electrical junction boxes mounted up-side down with weather tight covers. All sealed for no bugs etc...
Better explained with this trailer floor plan for my trailer.
My wiring is based for the WFCO 8900 series Power Distribution center..
My 1500WATT PSW AIMS INVERTER 120VAC ouput terminates in the panel mounted receptacle. This is my manual transfer switch for runing my trailer 120VAC items from my inverter.
Roy Ken
Roy Ken
