MEXICOWANDERER
Mar 20, 2015Explorer
Strain Relief
I used one for each cable. 1"
I smeared silicone dielectric grease onto the cable where the SR grabs it to seal it tight against acid fumes. The stuff in the next compartment is just too expensive. Del City is sorta screwed-up in their catalog. Go to the flexible pigtail page then a submenu link allows the user to click on regular SRs. I also used these SRs in the converter compartment, shore power cord - all over... the big job came with tail and clearance lights and nutserts. Stainless steel with stainless steel pan head Torx Screws. I put shakeproof external tooth lockwashers on each screw. Trucklite sealed lamps. 22-years never replaced a bulb. No streaks down the paint :)
