PatAndMarkRoadT
Apr 24, 2018Explorer
Confirming Bad Water Pump
I think I have a bad water pump but wanted a second (or third) opinion before I start the job.
Here are the symptons I encountered while dewinterizing and working to flush the lines:
1. Freshwater tank full.
2. Pump motor running (by sound and vibration)
3. No pressure building up.
4. Checked lines for leaks or missing caps using external water pressure. System is sound and sealed (best news of the day).
5. Shifted my pump inlet valve to Winterizing and drew no suction on a pan of water.
6. Based on number 5 above, I am convinced I do not have a priming problem or obstructed line to the full freshwater tank.
7. Conclusion: I have a bad pump and need to extract the motor/pump and replace the pump.
Would love to hear other proposed troubleshooting steps or alternate repairs before I open up the system this weekend.
Thank you in advance.
