jxjcksn
Mar 14, 2014Explorer
@ enblethan,
Perfect, I had come to much the same conclusion. Will need to check integrity of Neutral Buss to case ensuring no continuity, will need to ensure main breaker at house functioning for disconnect before rewire, intend to disable / disconnect everything other than 1 light in shed and 1 receptacle, have 30 amp breaker free for hot power and organizing proper receptacles and have 10/3 UF wire ready to go (XS from a Well rewire). Wiring to receptacle for trailer <25ft (estimate 18.5). Will ensure stainless steel self tappers used for ground buss bar if not supplied (Paint removed at contact point, Continuity tested before live phase). Initial connect to 1st ground should be <6ft from box. Using 6 Gauge copper for ground (unbroken to 2nd). Hopefully that should cover it !
Thank you for your reply and information Sir !
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
