enblethen
Mar 15, 2014Nomad
No, it does not require a main as long as there is less then 6 breakers to shut power completely off.
I would install a 30 TT receptacle for your rig and a 20 amp breaker for the barn if it is wired with #12. If you are not sure of the wire size go with 15 amp for barn system.
Main panel is normally the one adjacent to the electrical meter. A sub panel would be any panel fed off the first panel.
This panel will do what you want without breaking the bank. It will need the optional ground buss. I would verify the need for the optional ground buss as some panels come with a screw to bond the split neutral buss to the housing. You would have to remove the main bonding jumper.
Panel
Panel
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
