Dennis_M_M
Mar 27, 2015Explorer
Assuming this is a 12 volt light, it most likely is a bad switch since the switch should break the positive side of the circuit so no power can reach that light with the switch off.
Now, if it was wired like the French used to do on cars and the switch breaks the ground side, then you could have a short to ground somewhere between the lamp and the switch.
