Bobbo
Mar 28, 2015Explorer III
westend wrote:
If you have an incandescent bulb in that location, it's possible that it is being powered by a short to ground. A meter turns up this possibility instantly.
Not if the hot wire is switched. If the hot wire is switched, it would have to be a "short to hot", and that is only likely, you guessed it, at the switch.
