KJINTF
Nov 09, 2013Explorer
Have you "connected" to the controller using the serial cable?
My guess is you have NOT
You need to read from the controller it's exact network configuration
Download MSView - Open MSView - Open the Tristar MPPT setup Wizard - Create a new configuration - Make it a Solar Charge controller - Proceed to the Network Communications configuration page (5 or 6 pages into the configuration SETUP) .......This will be the standard default setting but might not be how yours is configured for - YOU will need to connect to the controller - Strongly suggest you do that with a Serial data cable a null Modum 9 pin D type cable - you will need a USB to serial adapter and setup the proper Baud, data bits, and stop bits for RS232 communications - The setup is clearly detailed in the manual
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
