ktmrfs
Nov 09, 2013Explorer III
Rmcgrath53 wrote:
I Have the ts mppt-60 with Ethernet port in the unit. I also have a remote ts-rm-2 that hooks to theRJ-11 socket. It also(ts mppt 60) has a rj-45 socket for Ethernet in the unit Thanks
the ts-rm-2 may be the problem I don't know.
see my previous post regarding communicating via the RJ-11 port.
If you have the remote meter connected to the RJ-11 you will likely need to remove that meter then set dip switches on the controller for the RJ-11 port to work with the serial port adapter that connects to the RJ-11 port.
And you'll need to get a usb-rs232 adapter.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
