mileena
Dec 18, 2017Explorer
kerrlakeRoo wrote:
DW and I both use machines, mine is a CPAP without the humidifier, (appears to use about 4 amps per hr) and hers is a BIPAP with the humidifier (uses as much as 7 amps per hr) Both are Phillips units capable of running straight from 12 volts.
If you wear the mask 8 hrs the energy consumed can be as high as 50 amps per night. for a single machine. So how big is you house battery? can it carry that usage without totally depleting the battery?
Thanks kerrlakeRoo! Not sure, since I don't have an RV yet. I use my van when I travel, but the downside is no power.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
