gkainz
Dec 18, 2017Explorer
thanks for the pic edit! Much nicer! And looks like you've gotten good advice above. A lot of us hose heads here!
You may find a place to actually install a second battery in your van, a deep cycle like RVs have that will charge from the engine electrical system, but not discharge your starting battery. Depends on how often you might use a setup like this to decide if it's worth it. Going that route would eliminate your need to seek out recharging plugs.
The next logical step (in my mind, at least) would be a solar panel on your van roof. I use a portable battery pack and portable solar charger when I tent camp (not often - the ground has gotten too hard!).
Oh, and ditto above recommendations to turn off the humidifier - it's a power hog!
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
