dougrainer
Jul 27, 2018Nomad
On Jayco, there is a 30 amp ATC fuse. This fuse is between the Battery and the INSIDE fuse panel. It is located in 2 places depending on the Year Jayco. On a short pigtail within 10 inches of the POS post of the battery. OR, on the front of the trailer ON the cross frame, there is a 4 by 4 metal box and coming out of that box is that 30 amp ATC fuse. IF that fuse is blown(it is) replace it, Your problem is solved. Also, if that fuse is blown, your truck will not charge the battery in transit. Doug
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
