pianotuna
Sep 29, 2020Nomad III
obiwancanoli wrote:pianotuna wrote:
you will soon tire of deploying portable panels.
That may be, but if it's the only way to charge the batteries, best to be able to tap into the sun
I dislike generators, but relying 100% on solar may not be wise.
If you are in a class C or class A with a v-10, it can safely be idled to recharge the batteries. Equip it with a dc to DC voltage boost device, and limit current to 1/4 of maximum alternator output.
If not equipped with a V-10, then a small generator may be a good back up source.
I do get six amps of charging at solar noon in leafy shade.
I do get three amps of charging at solar noon in the rain.
My solar farm is tiny at 256 watts, in comparison to your rather magnificent system, but now that I'm back to part time, it will be more than adequate when I upgrade to 600 amp-hours of SiO2 jars. My OEM system had ~437 amp-hours usable. (875 Amp-hours, total). I had no generator at all for 5 years. I never had to idle the v-10 in those 5 years. I ran out of fresh water before I ran out of power--and I cooked 100% electrically.
You seem to have deep pockets--so why not max out the solar panels on the roof--they are the cheapest part of the system, in terms of cost per watt. My cost per watt was $5.50 in 2005, for the panels.
Then, if you find you need them--buy some portable panels.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
