BFL13's avatar
BFL13
Explorer II
Nov 07, 2016
Controller as Converter ?
Somebody posted he is using his 15 amp controller as an adjustable voltage converter, but I can't find that thread to see how he did it. Anybody link to that thread? Thanks
The main problem, ISTR, was it was only a 15 amper.
Perhaps Mr Wizard's low cost 40 amp controller might work in that role if it can be hooked up however that guy did it with his too-small 15 amper. Two in parallel would be an adjustable voltage 80 amper for near $100 ???
https://www.amazon.com/Grape-Solar-GS-PWM-40BT-Controller-Monitoring/dp/B01FFNNUSK/ref=pd_day0_86_2?ie=UTF8&psc=1&refRID=FDF9K20XRGPQJNZFSY53
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    There are two ways.. I will post the proper way
    "Charger" with filtered output - Charge Controller - Battery
    NOTE not all chargers have filtered outputs.. if the one you have does NOT have filtered out, a "Hardening Condenser" or "hardening Capacitor" form a high end automotive audio store will provide the needed filtering.. I do recommend filtering.
    NOTE There are two types of controller as well.. One (and I'm not sure which) will work better in this configuration, PWM I suspect but the keyword is SUSPECT.. I'm not sure on that.
  • OK, I kinda see the purpose here. Carry on BFL, we always need experimenters to find the neat toys.
  • I have a couple ideas how I might use such a set-up if it would actually work. Too vague to specify right now :) Want to read that thread again first.
    EG, Suppose in a truck camper, you could swap inputs with a big switch to the solar controller input, between solar panels or the truck's alternator to camper input, and get the specified battery voltage for your particular battery type/model either way? (No gen to run a charger from in this sceanario)
    Also supposing I could use my existing solar controller selection, and not necessarily have to get one like Mr Wiz's. Would it need a buck converter in it (be an MPPT) or could a PWM (no buck converter) do it? Lots to learn before getting too excited. :)
  • Around here we call that going to Duluth by way of Mankato.
    Since there are devices that will deliver 80 amps at a range of lower voltages, a charge controller would only allow for the control or duration of the DC output.
    What is the interest or application of the use of a charge controller?
    I do recall that thread and think Mr Wizard is correct about the construction.
  • i seem to remember a thread, short TT, used an adjustable power supply (like a mega watt) for the input power, IIRC set it at 16v
    then used the solar controller as the charge controller
    but i'm running on memory and the details are a bit fuzzy
    all the items were up front in a cabinet near the entry door
    to be close to the batteries
  • It wasn't Mex. Might have been one of those alternator deals as the source, can't remember. Just that everyone thought using a 15 amper was sort of useless. But now here is a cheap 40 amper that might do it. The thread will say how he hooked it all up I hope.
  • Hi BFL13,
    You still need a power source. Mex did use a charge controller as a battery charger. I don't remember if he said what he was feeding it with.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 26, 2026
