bobsallyh
Jan 13, 2019Explorer II
MrWizard, they simply tap into the onboard low pressure system. Most fivers have either 30's or 40's. I didn't want propane on our worthless Onan, but instead have an 18 gallon onboard gasoline tank. But I sure would like to have a dual fuel system set-up, just for choice. LP sure isn't as efficient running a generator nor is it as readily available as gasoline as you stated.
