otrfun's avatar
otrfun
Explorer II
Aug 24, 2013
Converter 110 volt Input Current
Noticed the 110 volt input current to my converter fluctuates significantly with load. When the battery is fully charged, sometimes the 110 volt input current jumps from 1-2 amps to 6-7 amps by just turning on 4 or 5, 12 vdc lights. Is the converter simply reacting to the voltage drop (from the increased 12 vdc load) and increasing charge current/voltage to compensate? I assume this is normal? Thanks!
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 23, 2026
