avarusbrightfyr
Mar 26, 2020Explorer
BFL13 wrote:
The battery neg wire to frame still goes to the frame. The neg wire from the solar controller goes to the battery.
When the converter is unplugged you still get 12v from the battery. The converter only works if you have 120v from shore power or generator. (it also works from the inverter, but you don't want it to or you get that infamous "loop")
You can just buy a deck mount converter and put it up with the inverter and battery bank and leave the original converter where it is. No big wiring job. Put the controller in there too.
The battery bank needs a vented box because you don't want the inverter and converter to get ruined by battery fumes or the fumes to get a spark from the inverter. AGMs get around all that.
Good to know. I plan on either AGM or LifePo4 drop in equivalents at this point for the batteries.
