travisc
Apr 27, 2020Explorer
Flip the 120 breaker for the converter, plug everything in make sure the 120 stuff works, then put an volt meter on the 12v fuses and see if you get 12v, use the converter body for ground and the fuses for 12v. Flip breaker and take the same measurement. Our converter went out and was putting out low voltage , only figured it out after buying a refrigerator board I didn’t need, I have the meter plugged into the 12v side and the more 12v things I turned on the lower the voltage went. Best converter.con fixed that for us
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
Related Content
- Feb 01, 2026Community Alumni
