- wa8yxmExplorer III
ivbinconned wrote:
Is it because it’s cold here in the frozen Canadian climate?
It’s a WFCO 55 amp.
How do you know it stops? Most modern converters are rather silent. about he only thing that makes noise is the thermostatically Controlled fan. It will generally start when you first plug in (part of the power on self test) but then shut down cause... in your own words IT IS COLD.
A volt meter will tell you if the converter is converting... The basic rule is Not working = <13<13 equals working But depending on many things it might take a bit to come up.
(That's less than 13 not working actually 12.6 or less) and greater (13.6 is not uncommon) = working. more than 14 = bulk mode ivbinconned wrote:
Hardwired would be connected to a J-Box with romex. Not hard wired would have a 5-15 plug to go into a standard wall outlet.
What’s the difference there between the two 60 amp ones. The one says “hardwired”.
That’s not explained.
Is it compatible with lead acid as well?
Yes lead-acid is fine. I would probably get a Progressive dynamics for lead-acid as they have a longer absorption time. The smaller Boondocker (45 amp) would be slightly better with lead-acid as it will shift to normal (13.6v) at a higher state of charge.- BFL13Explorer II
You want the other 60 that has a plug in 120v cable , not the hardwire version if you get the Boondocker. He has two versions see his lettering explanation for the models. The Boondocker is a PowerMax, re-labelled. BoatandRV seems to be a better price and free shipping, but not to Canada sadly.
If you can get them to send it via post office it can save a fee compared with the other couriers AFAIK.
Yes, it works with any type of battery. You have to do the adjustments to the voltage for that mode, or you can just leave it in automatic three-stage for your Wets.
https://powermaxconverters.com/wp-content/uploads/2018/05/PM3-12V-LK-Manual-2018.pdf - ivbinconnedExplorer IIWhat’s the difference there between the two 60 amp ones. The one says “hardwired”.
Is it compatible with lead acid as well? ivbinconned wrote:
I would look at the 60 amp Boondocker.
It’s a deck mount.
http://www.bestconverter.com/12-Volt-Deck-Mount_c_264.html
This should meet the 14.6 volt charging of the battery and for lithium it has a very short absorption time.- BFL13Explorer II
ivbinconned wrote:
Yes I guess I should have. Normally I do. Guess I am getting lazy.
If I have to replace the converter is there a converter that is compatible with wet as well as Lithium?
And is there any reason to go higher in amperage?
This works with any battery spec, voltage adjustable, perfect for LFP.
60 amps is good for a 100AH LFP above 41F. From freezing to 41F you need a lower amp charger like 15 amps so use a regular car battery charger or whatever till the battery warms up.
https://www.boatandrvaccessories.com/products/powermax-pm3-60lk-12-volts-60-amp-power-converter-battery-charger-w-led-light - ivbinconnedExplorer IIIt’s a deck mount.
- Is the WFCO-55 deck mount or the slide in mounted in the lower section of the electric panel?
I would stay about same size unless you plan to pull new wire for the entire battery charging loop. - ivbinconnedExplorer IIYes I guess I should have. Normally I do. Guess I am getting lazy.
And is there any reason to go higher in amperage? - 2oldmanExplorer IIIf they freeze it's all over. Are you home? Take them out of the coach.
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 20, 2026
