Lwiddis
Apr 13, 2022Navigator
Yes, your converter should be specifically capable of Lithium charging for best results. However, if you opt for a Lithium battery way way over your needs, other settings, while not fully recharging your new Lithium battery, may be adequate. In regard to Ed’s comment, I elected to cut off the TV’s charging of my TT Lithium battery. I rely on my solar system and, as a backup, a Lithium AC to DC charger fed via the Silverado’s 120 volt plug when driving. Last in line is firing up my inverter generator…yuck.
