flyfishing48's avatar
flyfishing48
Converter/Charger Questions.
I have a one year old rig and thinking of replacing my WCO converter, or at least have a spare. Last season the stock unit quit charging for a day and started working again the next day. So confidence is low.
So shopping for a replacement but also thinking of upgrading the 2 6 volt batteries to Li batteries in the near future.
My questions are around the recharging.
My solar has a setting for Li so that should be good to go.
The truck is a 2020 Diesel bone stock ???
The stand alone converter/charger is a WCO and the amp rating is forgotten right now but I will be getting it before I purchase a replacement. I would expect I need to get a converter/charger that is LI compatible is that a correct assumption?
  • Yes, correct that you should get a charger that is LiFePO compatible. Also, if the engine alternator charges the house battery bank, you likely should get a DC-DC converter for that charge line to limit current excess draw from the alternator. (Lithium batteries can draw a LOT of current when being charged)
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
