ugeesta's avatar
ugeesta
Converter\Power Center Concern\Question
Last night I went to the trailer to turn on the fridge for this weekends trip. I connected the battery (12v new this year) and went inside to turn on the fridge and quickly found out there was no power in the trailer. Nothing worked.
So I went back and check the connections and fuses in the battery box and everything was good. Then I went to the breaker panel and flipped the breakers but nothing happened.
A few minutes later the power came on in the trailer. It flickered a bit but eventually stayed on solid.
After getting the fridge running, I ran the water pump and a couple lights and the power stayed on; good.
I haven't checked the trailer yet this morning, but could my converter be going bad? If the converter (or power center is starting to go bad, will it make it through the weekend? We have a generator for waking hours use but the CG we are staying at has quiet hours after 11:00 and it's supposed to get cold at night.
I'll be bringing extra blankets but momma won't be happy if we don't have heat at night.
Thanks.
Having RV issues? Connect with others who have been in your shoes.24,328 PostsLatest Activity: Oct 26, 2025
