ktmrfs
Nov 29, 2021Explorer III
dave54 wrote:ajriding wrote:
The ONE guy that actually answered your question with a pro/con list is correct, and another added that propane does have a cleaner burn and cleaner exhaust.
He also forgot that propane can store a very very long time, but gas has a shelf life.
That's about it for pros unless you are parked on your land with a big underground propane tank or would be using natural gas from the grid. The varnish build up from gas is a minimal one as that can be negated. Worried about replacing spark plugs? Stop, you can't afford propane to begin with.
The big con is the availability of getting propane quick and easy. Gas is easy and everywhere and unless I drive into the big rig section at the back of the travel center gas station there is always a gas hose just inches away. Doing a BBQ tank swap at the gas station or store is not a quick transaction either. The things people come up with just to make a comment...
An e way....
Thanks. I'm the OP.
No natural gas at home, on propane at home too. My I have several 20# bottles. I figure it is easier to carry a couple propane bottles than a couple of 5 gal gas cans. I can plug into the RV grill gas port if I need to. I have 2x7 gal bottles there. I have never had any problem getting my 7 gal bottles filled on the road. 5 gal bottles should be easier. Plus, I am in California. Propane is cheaper than the cheapest gas.
My real question (which I should have addressed in my original question) was how long does a 20# propane bottle last compared to 5 gal gas? Is it any quieter on propane than gas (they are getting old and are not as quiet as they once were, although still pretty quiet), and is starting the same whether really hot or cold weather. Like I said they are now 15(?) years old and, like me, can be slow to start on cold mornings.
to answer your questions
1) no difference in sound level I could notice between NG, Propane or Gasoline.
2) Run time. A 20lb propane tank holds about 4.5 gallons of propane. Propane has IIRC about 80% of the BTU/gallon vs. gas. So, I suspect you will get about the same run time on a 20lb propane bottle as about 3.5-4 gallons of gas. But you won't need to fill it up as often as on gas, unless on gas you have an extended run tank system.
3) starting on propane at low temps seems easier than gas. At high temps not much difference.
4) My conversion from hutch mountain works great, I converted a 2000 and a new 2200. but if you go this route check carefully on your SN, below a certain SN their kit doesn't work. I don't know if other systems have similar issues with early honda 2000.
5) Honda of course doesn't spec max output on propane or NG, but if is like most other dual/tri fuel generators, max output on propane will likely be less on propane, especially on the 2000. It's engine is pretty much maxed out with the 2000 engine. The 2200 with only 200more watts, has a 25% larger engine. And it will still put out near or full output even at 7000ft altitude, so it may not have as much restriction on max power as the 2000.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
