dougrainer
Jan 13, 2022Nomad
A Gasoline powered Onan is exactly the same as a LP powered. The ONLY difference is fuel to run it Gasoline or LP. You read about problems with Gas powered Gensets because they are probably 95% of all RV Gensets. The ONLY problem with Gasoline Powered Gensets is the USERS fault, not a design problem. Gasoline Gensets need to be run at least 1 hour a month. This keeps the fuel from deteriorating and gumming up the Carb fuel jets. Same is true for Home lawn equipment. Don't properly treat and store your Gas powered Home appliances, you will have a ruined appliance. Having a LP powered Motorhome in a Gasoline and Diesel powered Motorhome LOWERS its resale value. LP powered gensets are limited by the size of the ASME LP tank on the motorhome. Usually the LP tank has no more than 25 to 27 liquid gallon capacity. LP powered Gensets consume 1.1 gallons LP at full load and about .7 gallons at 1/2 load. So this gives you at best 20 to 24 hours before LP tank refill. Even less if you are using onboard LP appliances. Gasoline Powered gives you 80% of the Gasoline tank capacity at .9 gallon 100% load and .6 at 50% load. You could go 3 to 5 days 24 hours a day. AND, LP gensets are also prone to problems from gummed up LP regulators. Especially when it is hot outside. Doug
