Grit_dog
Jan 13, 2022Trailblazer
hedgehopper wrote:
I am considering the purchase of a Class A with a gasoline-fueled Onan generator and have heard a lot of horror stories about problems with such generators.
Here's a funny story to counter your internet wisdom about the horror stories of gas powered Onans.
Camper in sig, bought last year. Orig owner literally used it like once or twice the first year and it sat since 2017/2018 unused.
Had it advertised as a propane generator.
As I really didn't want LP gen and also didn't believe him, I asked multiple times. (Camper is 300 mi away at this point, can't just run over and check it out) Answer was the same. "I've started the generator several times, and have to turn on the LP, light the stove and only then will the generator start!"
(Some of you will be really laughing by now...)
Regardless, I head out to inspect and buy it.
He goes through the whole deal lighting the stove to fire up the genny.
Turns out he had NEVER added gas to the gas tank. There was apparently just enough gas still left to run the generator (from the selling dealer when new??) as it read empty and the fuel station pump only pumped air.
Bottom line, that generator actually fired up and ran somewhat acceptably on what had to be 4 year old gasoline!
Not recommended, but....it runs much better on gasoline purchased in this decade!
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
