- MEXICOWANDERERExplorerCall your propane distributor. They sell hats that fit atop a standard carburetor. They are experts and can guide you point by point.
- DrewEExplorer III
j.p.f. wrote:
I bet it would be cheaper,easier and faster to sell your gen and replace it with a multi fuel gen.
I also have a hunch that this is true. Besides a gas carburetor, you would need a fuel pump, probably some sort of a choke linkage or setup, and possibly a different or modified control board to turn the fuel pump on and off as appropriate, perhaps among other differences. - Horizon170Explorer
SaltiDawg wrote:
Not disagreeing with the suggestion that it may not be practical to accomplish the Mod you want, but I certainly would not shop for a "dual fuel" carb.
Rather, I'd look for a compatible gas carb for your generator and piggy back onto it with a Propane Kit. That will require no modification of the gas carb.
To get a sense of whether it is practical, goto US Carb's Forum. They are helpful and knowledgeable folks there:
US Carb Forums
You are correct. That is what I did to the BU gen. at home except that I converted to gasoline/Natural gas.
I had to drill one additional hole in the existing carb.
I have sent some e-mails out requesting info on a carb. Then I can get a propane kit from US CARB.USCARB
Marvin - SaltiDawgExplorerDeleted by Poster.
- j_p_f_ExplorerI bet it would be cheaper,easier and faster to sell your gen and replace it with a multi fuel gen.
romore wrote:
You need a dual fuel carburetor to fit your engine, if available it won't come cheap. After my experience with a dual fuel fork lift which we finally converted to straight propane out of frustration I would recommend leaving it alone unless you have a specific need.
The specific need is to add to the options of my Survival plan.
The conversion I did works great but it is my home back up gen.
Marvin - romoreExplorer IIYou need a dual fuel carburetor to fit your engine, if available it won't come cheap. After my experience with a dual fuel fork lift which we finally converted to straight propane out of frustration I would recommend leaving it alone unless you have a specific need.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
