BurbMan
Jul 17, 2017Explorer III
Bear in mind that if the 5er has 30-lb portable LP tanks like I have on my TT, those are a lot easier to fill than the built-in tank on most MHs. With an auto changeover regulator, you can take one tank off and get it filled while you still have capacity in tank #2, so you are never totally out.
At 3 lbs/hr at 1/2 load (from post above) that means about 10 hrs of gen time before tank #1 is empty, assuming minimal usage for fridge and HWH.
I would be inclined toward push-button convenience of the propane, but I think a lot depends on how you are camping...
If you are using the gen just to charge the batteries and for occasional micro/hair dryer usage, then propane is the way to go. If you are going to park out on BLM land for a few weeks and run the gen 24/7 for a/c, then gas is probably your better bet.
I would use the built-in as the primary, and if a trip is likely to call for heavy gen usage, then bring the gas along and use it instead.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
