STBRetired
Jul 17, 2017Explorer
One thing to consider. If you run propane and run out of fuel, there is no fuel for your refrigerator, stove, or water heater as well. If you use gasoline as a fuel, then if you run out of gasoline, you can still run your fridge, stove and water heater until the propane also runs out or the batteries go flat.
Having 2 different fuels can have its advantages when they run out, as long as they don't both run out at the same time.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
