pianotuna
Jul 19, 2017Nomad III
Hi Mex,
This may seem counter intuitive but it does work well.
I first encountered clammy cold in Hannibal, MO. The RV was cold but it was uncomfortable to say the least. I did have a good 30 amp connection, so I turned on a 700 watt electric heater. Within an hour R.H. had dropped and the RV was comfortable to be inside.
So, if you have a heat source and an air conditioner you may be able to make yourself comfortable again. Heaters, of course, are much less expensive than a dehumidifier.
I've even been known to add a heater when the dehumidifier could not keep up with the task of reducing humidity. The nicest part is that there is no bucket to empty.
MEXICOWANDERER wrote:
Clammy heat is inside with 85F and 60% R/H not outside. Oooooo as I write this, it's 83F with 67% R/H. To keep the sweat down a fan is blowing on me, my arms and legs have cold skin and my head is sweating. My beloved dehumidifier is thousands of miles from here.
