_40Fan
Aug 13, 2014Explorer
samert wrote:Bull Rider wrote:
I do hobby welding. I have a TIG welder and a MIG welder. I TIG weld stainless steel. There are a TON of different types of stainless steel, and a TON of different types of filler wire. Some of it is very specialized.
If you want quality input from people that know everything to know about welding, post your question and photos over at Weldingweb.com
The guys/gals over at Weldingweb are very helpful, but can be colorful and harsh too, just so you know in advance.
Also provide information on who welded it in the past, and any other photos. Include clear close up photos of the weld.
You will get an answer, probably more than you need.
My original description may have been a little confusing. The last time it cracked (2008) I cut out and replaced the tube coming off the turbo. Then I noticed (last Sunday) it had cracked again, same place as last time. I couldn't get a new tube in time for my upcoming trip, plus if I keep cutting out the old I will run out of length on the pipe it's welded to. So I had the maintenance welder at work repair the crack by welding it on the inside of the pipe filling in the rib where it seems to crack. I put a jamb nut inside the saddle on the clamps so I could leave them a little loose on the pipe this time to allow it to expand & contract but still support the assembly. Hopefully it will hold up this time.
Exactly what I would have done. I bet it will hold up.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
