pigman1
May 26, 2020Explorer
I've been using the same hammer crimper for more than 10 years for the RV and a wide variety of farm equipment. Very small and easy to store and use. Never a problem with any lug/wire connection that whole time. The big trick is to make sure you're using the correct size lug for the cable size. We've never had any connection with corrosion, but I slip a 2" of piece shrink wrap on the wire before making the connection then slide it up over the lug shank and heat.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
