CA_Traveler
Jan 05, 2014Explorer III
Now I'm even more confused. If it's intended as a isolator as in charging 2 battery banks then every MH I've owned has one. Trailers on the other hand don't normally have 2 battery banks and hence don't need a isolator.
By isolator do they mean it disconnects the tow alternator from the trailer? That function is very common in the US. As a DIY project a $5 relay will do the job. And I'd guess that most factory tow packages supply 12V only when the engine is running.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
