JSS1439
Jul 30, 2014Explorer
nuggetthunter wrote:
Yes, the vacuum breaker is the same part. The vacuum breaker is designed to gradually open the choke when the generator is running until the unit is warm enough for the mechanical choke pull off to overcome it. You may not be able to remove the vacuum hose to check it with the breaker installed. Very short hose in close quarters.
If you need it the replacement part number is:
Vacuum Breaker Kit A043B658 (Old Kit # 170541-1222)
Hope this helps you out.
Great info. thanks!
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
