Well, I'm enjoying some R&R camping, but, after 3 days of cloud cover, the solar isn't keeping up at all. My 24v system is down to 24v. You'd think 800w of solar on 4 batteries would do it, but no...
I found 2-12v chargers and I did try hooking them up in series.
I set both at the 10a rate, but the measured voltage in series was only 22.5v. The older charger at its 10a rate would only pump out 12.7 volts. I tried using its 30a rate which upped the voltage to 13.3, but the amperage was too high and the cables got hot quickly.
I'll just use both chargers seperately at 12v for now.
