marcsbigfoot20b
Oct 05, 2018Explorer
Is there a belt on the AC compressor and is it tight?
Is the AC compressor clutch engaging and spinning?
There are so many things it could be.
Low on refrigerant
Low pressure cycle switch problem
Clutch bad/compressor bad
No power to clutch
Bad AC control
ETC
If the clutch does engage for a few seconds then shut off, over and over, then most likely you are low on refrigerant.
Low on refrigerant
No power to clutch
Bad AC control
ETC
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
