1995brave
Oct 05, 2018Nomad
Noel wrote:
Had a friend go under coach when running A/C. He saw belt/pulley jump a bit when the buzzing cycled. Noise is under coach, in back of two thermostatically controlled fans...only one was running. Ambient air was 50 deg and incoming dash air was 46 deg. Felt both A/C hoses and one was not colder than the other.
Was this helpful...?
Looks like you may have three problems.
1. Cooling fan for radiator bad.
2. Belt too loose or compressor clutch going bad.
3. low on Freon.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
