Washtubman
Jan 05, 2015Explorer
Dash AC Problem
My dash AC stays on regardless of the switch setting. The compressor appears to stay engaged all the time. It's a 2006 HR with Workhorse 8.1. Where do I Start??? Thanks for any help.
ernie1 wrote:
Not saying this has anything to do with your primary concern of the compressor not shutting off but is in regards to your statement of the air compressor sound from your ac compressor. You really should have a set of ac gauges hooked up to your ac system. This will tell you many things that is or is not wrong with the system and/or what is causing the noise you mentioned like maybe excessive high head pressure, something internal like a rod clanging etc. You mentioned that the noise occurs after the system is run awhile so I was thinking increasing head pressure. Has the unit been worked on recently and maybe the refrigerant charge has been contaminated with air and moisture which will cause very high head pressures?
j-d wrote:
Doggone! Relay was supposed to solve ALL the problems! You can see from the few pins it has and the diagram on it, that all it's able to do is be ON or OFF when told to. Other odd behavior is coming from somewhere else.
Couple more questions:
Did the Compressor run in all selections before?
Are your A/C controls Manual or Electronic?
Does that Manual linked in this thread match your Coach?
Did the sound of the compressor change from before changing the relay to after changing it?
Do you know if your system is meant to cycle? Many modern ones do not.
j-d wrote:
This Link is "A" Workhorse Manual. Maybe matches yours, maybe not. I found the A/C Compressor Relay in the "outside" fuse box and it's pictured as a square relay, looking at it from the top. Is this thing a Cube. around an inch on a side? If it is, could well be a "Bosch Relay" and here's the wiring diagram for it.If yours has five terminals, there should be continuity between 30 and 87A with the relay out of the vehicle. Out of vehicle, between 30 and 87 should be OPEN. 85 and 86 are the coil that pulls the relay into contact, so there should be continuity across them. If you have test leads, you can put 12VDC to 86 and ground to 85. Relay should click and then 30 and 87 would have continuity. 30 and 87A would now be OPEN. Not every Bosch has five terminals. If it doesn't then just disregard what I said about 87A.
ernie1 wrote:
Could it be because you have the heater set on the defrost mode?
wa8yxm wrote:
Two things .. The switch and optionally a relay.
