pianotuna wrote:
eric,
I think you mentioned you use a trik-l-start. If wired between house bank and chassis battery there will be up to 5 amps of charging. This would also happen with the generator powering the converter.
Let me know if I am not remembering correctly.
This coach does not have a or need a Trik-L-Start. That was in my Class B. Funny thing, I bought one to install in this coach before I understood how the battery control system worked and it is on a shelf in my garage.
Simply put, the battery control in this MH will charge both battery banks if it senses a charge on either one, from any source. The alternator will charge the chassis and house batteries and shore, generator or solar will charge the house and chassis batteries. It will isolate them during discharge. It's pretty slick but it's also the reason I'm having issues with my charge light.
