ktmrfs
Apr 29, 2017Explorer III
mchero wrote:'
"The best ones do ACrms, DC or ACRMS+DC current."
Is this typically specified in the specs?
Thanks for all the reply's.
you would be able to tell by the selections on the meter. and it should be in the spec's and manual.
for most RV applications DC and ACRMS will cover almost all your needs. AC range needs to be 0-50A at least, DC depends on your needs, but 0-50A min, and if you have an inverter or anything else drawing a heavy load 0-400A in several ranges.
it is nice to have a peak hold function. that way you can see what peak currents are, like starting a AC unit.
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Jul 22, 2026
