Harvey51
May 03, 2017Explorer
I have a Uni-T 204A and am very happy with it.
Be careful when buying a cheap clampmeter - some say "AC/DC clampmeter" when in fact the current range(s) are AC only. A "magic" Hall Effect device is necessary to measure the steady magnetic field around a DC current carrying wire and having that name in the description guarantees it can measure DC current. This one clearly shows high current DC ranges.
http://www.ebay.com/itm/DC-120V-100A-Battery-Monitor-State-of-Charge-Remaining-Capacity-AMP-Voltage-AH-/182147916411?hash=item2a68dca27b:g:gWUAAOSwyQtVz1vp
The accuracy is indicated in that description, too. Mine is not all that great at low currents but I can tell a parasitic draw from a battery within 100 mA without resorting to opening the circuit to run the current through a multimeter. The advantages of the clampmeter are not having to open the circuit and no risk of burning out the current range on your meter.
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Jul 22, 2026
