red31's avatar
red31
DC Hz and duty %
I've been trying to measure PWM frequency in abs with both probes of a DMM, with just one probe I get a reading of freq and duty cycle %.
Do I only need one probe?
Seems for AC, one probe I get 60 Hz and ~50%.
  • Panel v. my last controller the v meter would jump all over (abs) from vbatt to voc and between, the new one has a fast enough freq to display PV ave of vbatt and voc (abs). I saw a video (part 1 & part 2) of 30 hz and 15 hz controller and was just curious. Part 3 uses an oscilloscope.
    https://www.youtube.com/watch?v=QqxI-l5a6d4
    Salvo wrote:
    You're better off measuring the input to the charge controller. In other words the panel voltage. It will have two states, either Vbat or Voc (open circuit panel voltage).
  • DrewE's avatar
    DrewE
    Explorer III
    If you have an ammeter shunt in the line between the charger and the battery, try measuring on either side of the shunt. The voltage across the shunt may not be sufficient for the multimeter to pick up on, but if it does work it should give a good reliable answer.
  • The non-connected probe is acting as an antenna and is picking up 60 Hz through the "air".
    You need to connect both probes. There isn't going to be much of a signal at the output of the charge controller. The battery will keep voltage at Vabs. You're better off measuring the input to the charge controller. In other words the panel voltage. It will have two states, either Vbat or Voc (open circuit panel voltage).
Having RV issues? Connect with others who have been in your shoes.24,360 PostsLatest Activity: Feb 13, 2026
