MalcalExplorerSep 24, 2015DC will not workI Have A 2006 Cardinal Fifth Wheel When I am not plug in to 50 amp. Slide out jack lights do not work. And will not work plug in to the truck I have replace the battery what do I need to check next....Show More
SAR_TrackerExplorerSep 24, 2015OK, we can rule out the converter, since the slide works hooked up to shore power (the 50amp you talked about).Put a volt meter on the battery(ies), and check with the shore power plugged in, and then disconnected. Big difference? Bad battery(ies).
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
Related ContentNot all Aftermarket bumpers workStorage and Work Space Near PortlandFridge not working/freezer kind of working2007 Thor Mandalay 40H power step stop workingNew Working LGDs
