GordonThree's avatar
GordonThree
de-humidifier drain line
I'm thinking of drilling a hole in the floor to install a drain line for my de-humidifier. Likely spot will be next to the low point drain for the FW tank, which is inside the cabin under the bed. The machine sits in a storage space at the end of the bed between it and the outside wall.
One thing I'm concerned about, what should I do to keep bugs from nesting inside the drain line, or crawling up it into the machine itself? What are some other reasons not to, that I might be missing?
I thought about draining it into the gray water instead, but the machine produces 2-3 gallons per day, that's a lot of water to be running into the gray in addition to my own wasteful behavior at the sink / shower.
  • Screening over the end of the drain hose secured by a hose clamp OR copper wool stuffed inside the first inch or so of the drain line. Don't use steel wool as it will rust quickly. Hope this helps.
    Happy camping.
Having RV issues? Connect with others who have been in your shoes.24,303 PostsLatest Activity: Aug 21, 2025
