wa8yxm
Jan 08, 2015Explorer III
Heck, you coudl (if you have the space) drop an additional breaker in your main breaker box.. This would accept either shore or Genny power,, but you (in theory) know enough to kill the A/C and Microwave before compressing air.
yet another suggestion.
I ran TWO lines to a box I installed (Weather proof utility box) it has an outlet and a plug, the plug feeds the Rear A/C on my 50 amp rig, the outlet is fed by the 20 amp breaker that used to feed the Rear A/C, Plug the plug into the outlet, all is normal, Unplug and I have power for the air compressor, OR an alternate way to feed the rear A/C (off the park's 20 amp outlet). works great.
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Jul 22, 2026
