CA_Traveler
Jan 29, 2015Explorer III
vermilye wrote:Typo? Transfer switches switch the hot and neutral. Grounds are all bonded. On board gens should bond the neutral and ground so that with gen power they are bonded for the rig and the transfer switch isolates that bonding from shore power.
If your transfer switch makes/breaks the neutral/ground bond, running a separate bonded receptacle may lead to problems with plugging the RV into a GFCI receptacle. May or may not be a problem, depending on the wiring of your RV.
There shouldn't be a GFCI problem but like you said it all depends...
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Jul 22, 2026
