MEXICOWANDERER wrote:
I am building one in my shop for another forum member. There never has been a "push a button and it does it all" battery charger so start thinking about compromises. BFL13 has tried many and has come up with the least offensive compromise.
Mex means the one in the photo here. You can actually make any deck mount converter into a portable charger. Just cut off the end of a set of jumper cables (with big enough ampacity AWG) and stick that in converter's terminals. Big "parrot" clamps are ideal.
This is a PowerMax 100 amp Adjustable model. You want the adjustable model, not the ordinary 3 or 4 stage, so you can choose the various voltages you need for the different charging jobs you mentioned in the OP.
