SDM
Mar 23, 2018Explorer
Def fluid
Have a 2011 Duramax. Have had a sensor problem. Dealer says the def from Walmart is giving some problems. Any thoughts.
Wild Card wrote:
They make a DEF refractometer. You can buy one at most auto stores. Take your own sample then you'll know.
Rancher Will wrote:
I own a small trucking company, two cattle ranches and I pull our Montana 5thWheel with a diesel RAM truck. On average I pay for over 150 gallons of DEF per week. I learned that I save over $2.00 per 2-1/2 gallon jug by my employees buying at WalMart rather than at truck stops and other sources. We have had no problem with WalMart DEF in the Blue jugs plus it is cheaper than even bulk supply.
joebedford wrote:REWahoo wrote:Yes. I believe the special warranty is 10 years and/or 120000 miles.joebedford wrote:
I have a 2011 Duramax. The DEF tank was replaced TODAY because of sensor or heater or sender problem.
Was it replaced under warranty?
My dealer said the sender was bad in my 2011, it wasn't covered by warranty (less than 70,000 miles, still under warranty) and wanted $1,100 to replace the tank.
I added more DEF, the warning light went out and I'm still driving it.
