MEXICOWANDERER wrote:
"My inexpensive Schumacker charger does not seem to be working. I can hear it running but if I put the pos. & neg. clips from my volt meter on the battery terminals I get zero reading. Is this how you check a charger?
Thanks"
I merely responded to the question not a permutation. Ten Thousand Excuse Me's...
:h
No need to get offended.
OP could have set the meter to AC volts instead of DC volts which would show ZERO volts on the display...
Thousands of things are just plain wrong with the OPs post..
Using a car charger on a 6 Ahr gell battery is a bit like using an atomic bomb to go fishing.. Results will be a disaster...
New gell batteries for game cameras cost what a whole $25 and the proper charger which is typically stocked right beside the battery is a whole $15...
Just not sure if the OP is joshing us or not..
