MEXICOWANDERER wrote:
I thought you were measuring CHARGING voltage or at the least CHARGING amperage.
What voltage do you have AT THE CHARGER when it is plugged-in and switched on?
At this point in time, it really doesn't matter.
The OP is attempting to use a car battery charger which most likely at the minimum has a 2 Amp charging rate and at the worst 10A-50A charging rate. This kind of current will easily over heat/charge a 6 Ahr gell batter which is used in game cameras.
Chances are the battery was run flat (10.5V or less) sitting in a game camera too long and is beyond trying to massage back to health..
My suggestion is to not worry about the charger, it is most likely OK and if it was a smart charger it saved the OP from a possible battery fire...
The OP NEEDS to buy the PROPER charger designed for charging a game camera battery...
Gell cells are very picky about float and cycle charging voltages and extremely sensitive to over charging and being left in a partially or completely discharged state.
Assuming from the OPs post that there is NO voltage on the battery terminals (IE no "change"), OP most likely will need to buy a new battery AND the correct charger for this application...
